I have some Japanese Karaoke Disc that the file names are .DAT
I tried playing them in VDJ but it wont work, is there a plug in for that or any other way I can use them?
geposted Tue 28 Sep 10 @ 2:12 pm
Hi,
try to rename them to .MPG, then VDJ will play them. Apparently they only have another extension.
geposted Tue 28 Sep 10 @ 2:22 pm
OMG!! you frickin ROCK!!!!! That is all it took! I owe you a Mai Tai!
geposted Tue 28 Sep 10 @ 2:31 pm
Whenever I'm around...
Funny how simple things can be ;)
geposted Tue 28 Sep 10 @ 2:36 pm
2 of the 4 discs let me do that, for some reason two of the discs will not let me click and drag them to a folder.... but at least I have 50% more than I did! LOL
geposted Tue 28 Sep 10 @ 9:28 pm
You just need to add the *.dat extension to the codecs panel in the vdj set up... just follow the numbers on the image .
geposted Tue 28 Sep 10 @ 10:08 pm
ahhh you rock!!
geposted Tue 19 Oct 10 @ 5:51 pm
