hey guys whats up im thinking about buying the
PRO MIXER DJX750 from behringer but was luking to find out does any1 use it and what do you think??? thinking about using it wih the v7 until the x7 comes down in price a little what do you think!!!!!!!
geposted Wed 29 Sep 10 @ 5:20 am
Save your money...stay away from Behringer mixers,simply they dont do for the job...http://www.mixexperience.com/products/product-detail/vestax-vmc-004-xlu.html I should give some more and get this instead
geposted Wed 29 Sep 10 @ 6:53 am
cheers buddy..
geposted Wed 29 Sep 10 @ 7:30 am
I do have a Behringer DJx750 and i was wondering if anybody could help me on applying it to virtual DJ, ive been running it off of CDs and i dont know what cable i need, or even how to make it software based, please help. im using it with two gemini cdj-210 turntables
geposted Tue 07 Dec 10 @ 2:16 am
This mixer has no control over VDJ AFAIK, so you have to use it in external mixer mode just like any other.
geposted Tue 07 Dec 10 @ 3:00 am
so, is that a no? im sorry im new to the realm of DJing
geposted Tue 07 Dec 10 @ 6:14 am
I have the ddm4000 and have had no problems with it at all. cant say for the other models they make though, as I have only used the ddm400 with behringer.
geposted Tue 07 Dec 10 @ 6:15 am
I have used a Behringer before, and it was the shattiest mixer I had ever laid eyes and hands on. Then I tried, then bought a DDM4000, and am pleased with my purchase. This should be (if it's not already) Behringer's flagship mixer. It's the only one I have seen or heard about that they have gotten right.
geposted Tue 07 Dec 10 @ 6:24 am
One of my mates has a Behringer mixer that is a rip-off of my DJM-500.
Looks is where it ends unfortunately. It is a dreadful impersonation and sounds terrible.
Spend a bit more money and get something decent.
Keith
Keith
geposted Tue 07 Dec 10 @ 6:44 am
Plus with that mixer if you ever wanted to mix video you'd have to map another fader or knob cause that crossfader wont do audio and video at the same time like a.higher quality mixer. Just something to also look at.
Huey
Huey
geposted Tue 07 Dec 10 @ 7:01 am
