i have just had to get new laptop with windows 7 .i have installed new drivers from numark downloads .problem is deck running slow and jerky.i was previously using vista with no problem . Any ideas what i can do?? Any advise welcome.In the MEANTIME i am getting sound to my mixer via headphone socket on laptop. Bazooo.
geposted Wed 29 Sep 10 @ 10:12 am
Have you Checked the programs running whyle you are djing. I had the same issue with my Rmx and with the program running I was at 51%. that was to high. I entered msconfig and looked at my startup programs only windows needed programs running now and I am at 27% usage with VDJ & Video running. Remember you have virus software running and if you are using split/dual screen it will also cause some slowing of your system. Hope this helps you out some & im sure you will get much better advice later on from the geniuses on this site just thought I'd give mine.
Keep Mixing
Mr Rizo
Keep Mixing
Mr Rizo
geposted Thu 30 Sep 10 @ 2:57 am
