Hi everyone.
There is a plugin to download in the controllers section of virtual dj for the HC4500 and works with Virtual DJ 6.0.7 if I download this where do i put it? Also a message for jpboggis are you still using HC4500 and if so have you got it working the way you want it I love your plugin for 5.2 just wondering if you have tweeked it to work with latest virtual dj.
many thanks
many thanks
geposted Thu 30 Sep 10 @ 5:55 am
v6 mappers need to be copied to My Documents\VirtualDJ\Mappers
Sorry, the DLL custom mapper for the DN-HC4500 is obsolete and no-longer supported in v6. We would strongly recommend customising the default mapping to suit your own personal preferences.
I do still use the HC4500, but with the default mapping with a few basic modifications - Mainly the A1/A2/B button mappings which you can find at the bottom of https://virtualdj.com/wiki/VDJScript%20Examples.html
geposted Thu 30 Sep 10 @ 12:25 pm
