Hi there
Apologies for what may be a basic question but I'm quite new to this...
I would like to produce a regular music podcast and want to integrate a mic with VDJ so I can present the podcast (talk in between the tunes I'm playing). I believe I need an external mixer to do this. Since I only need the mixed to support the mic I dont need anything too fully featured so is anyone able to suggest a very low cost solution that is compatible with VDJ and is there anything else I need? I have a fairly basic soundcard on my PC.
Any help greatly appreciated.
Cheers, Mick
Cheers, Mick
geposted Fri 01 Oct 10 @ 6:06 am
for now u could use win amp with shoutcast to broadcast to the net.
You could also try using butt (works on pc and macs)
geposted Fri 01 Oct 10 @ 7:18 am
Hi there
I am thinking of buying the Hercules Steel product and using it in conjunction with VDJ. For mic support, will I need to get a new soundcard for my PC (I currently have a basic soundcard supplied with the PC)?
geposted Fri 01 Oct 10 @ 10:33 am
