I i'm just wandering if it's possible to use the Hercules Dj Console Rmx + NanoKontrol at the same time.
Anyone knows if it's possible?
geposted Fri 01 Oct 10 @ 4:44 pm
Yup you can use multiple controllers. I use a midi mixer and the nanokontrol. Not sure if it matters though cause your a limited edition user. Just hook it up and try it, lol!
Hope that helps
I
Hope that helps
I
geposted Fri 01 Oct 10 @ 5:44 pm
You will need to upgrade to VirtualDJ Pro to use other MIDI controllers:
https://virtualdj.com/buy/
geposted Fri 01 Oct 10 @ 6:12 pm
Like i've already said to more Atomix Staff users, my home version is the LE (that came with the rmx), and the pro version i use is installed in the notebook of the bar, that was there before me.
The Dj before me so i heard asked the owner for buy it and it was installed on the notebook from the bar.
So as i am one of the dj that uses it in fact i use the pro version to play and not my LE version, that i use to train in my home.
geposted Fri 01 Oct 10 @ 6:18 pm
