Dans le cadre d'une soirée exceptionnelle organisée dans mon établissement, je souhaite savoir quels sont les codecs/formats de vidéo à éviter afin d'écarter tout risque de plantage dans VirtualDJ. Je constate qu'avec mon PC qui gère les clips (indépendamment de la musique) il arrive que VirtualDJ plante avec certaines vidéos (notamment les formats HD).
Merci
Merci
geposted Sat 02 Oct 10 @ 8:14 pm
Bonsoir,
si vous comprenez l'anglais ceci est de bonne manufacture pour vous répondre :
There are several parameters which determine the speed with which VirtualDJ decompresses and displays video content – the size of memory present on your video card, the speed of the graphics processor (GPU), the speed of the main central processor (CPU), and the access speed of the hard disk.
Another parameter which largely influences performance is the type of file. An MPEG1 format file is much faster to decompress than a VOB format file. In a similar way, a file with a 320x240 resolution is much faster to decompress than a file with a 720x576 resolution.
By default, VirtualDJ decompresses only the content which is visible in the video mix window. This means that if there are two clips which are playing but only one is visible, VirtualDJ will only decompress the video which is visible. If both video files are shown in the mix window, then VirtualDJ will decompress both. This makes the software perform quicker and also allows it to perform better on slower machines. However, this may result in small jolts at the time of transitions.
And finally, we recommend the use of an output resolution no greater than the resolution of the video files. If using higher resolutions, low-resolution content will not look any better but will be using more computer resources. A resolution of 800x600 should be sufficient if using high-quality DVD video.
bonne soirée, Yan alias Dj Rewop
geposted Sun 03 Oct 10 @ 4:56 pm
Salut Dimitri,
Pour ma part j'ai toutes mes vidéos converties en .Mpeg2 en 640*480
C'est un format standart d'une qualité correcte pas trop difficile à décompresser pour VDJ (a priori)
Après c'est surtout la puissance de ton ordi qui est important.
Je te conseille :
Dual core 2.4 Ghz 2go de ram
Carte vidéo nvidia ou ATI 256mo DDR3
Dans la partie vidéo dans config du logiciel tu peux baisser les performances de VDJ si tu as des grésillements ou des lags.
Pense également à désactiver ton antivirus pendant ton set.
Bon courage
Guillaume
Je te conseille :
Bon courage
Guillaume
geposted Thu 07 Oct 10 @ 8:19 pm
J'utilise différents types de vidéo : mkv, mpeg, avi, vob.
Ce sont soit des vidéos de youtube, des enregistrements tv ou des rips dvd.
Et bien bizarrement, je peux passer certaines vidéos plusieurs fois sans aucun soucis et un soir pas fait comme un autre, ça plante.
Pourquoi, je ne sais pas et je n'ai jamais trouvé un lien entre le format ou le type d'encodage et le plantage de VDJ ???
Dans l'ensemble, ça fonctionne pas mal, mais ce n'est pas 100% fiable.
A+
A+
geposted Fri 08 Oct 10 @ 2:10 am
