Hi Any1, i am using virtual dj and when i load certain songs in the playlist they don't play but if i load it in the deck A/B it plays! Does any1 know what causes this to do this, as its a pain when playing at a disco and the song on the playlist does not play and it jumps to the next available song.
Would appreciate any1 comments on what causes this to happen?
Thanks
Thanks
geposted Sun 03 Oct 10 @ 6:07 pm
Thats because the files that are not playing from the playlist have been moved or changed filepath, filename etc. You have to relink manually those files in the playlist.
geposted Sun 03 Oct 10 @ 6:34 pm
Hi if it helps the playlist i have has been created for months and has been working ok, but over the last few days when the song plays for several seconds then jumps to the next song. If it helps any the small speaker symbol is shown orange. After reading the manual this Indicates that the BPM difference between the analyzed song and current playing song is too great. This is a track that you might wish to avoid playing next!
If this is the case is there any way that i can change the settings on the bpm or do something else so that all songs in the playlist can be played properly without it jumping songs.
I would appreciate if someone could give me any ideas in how to rectify the problem?
Thanks
Thanks
geposted Mon 04 Oct 10 @ 7:39 am
What version are you using cause I've had this happen in older versions. Maybe you should download the latest version and try that. Then if you like it go ahead and purchase it. It a great investment plus there are many perks to being a licensed user.
Hope to see you with us soon
Huey
Huey
geposted Mon 04 Oct 10 @ 7:43 am
Hi forgot to say im using virtual DJ 6.0, hope this helps.
Thanks
Thanks
geposted Mon 04 Oct 10 @ 7:53 am
This Version is so old :-( Please update to the latest one. There are many problems fixed.
Greets, Heiko
Greets, Heiko
geposted Mon 04 Oct 10 @ 8:00 am
download the latest demo 6.1.2 .....
purchase the Premium membership ........
https://virtualdj.com/products/membership.html
multiple double blind, peer reviewed studies suggest that Premium members get laid a LOT .....
geposted Mon 04 Oct 10 @ 5:04 pm
