Forum: Old versions
Topic: probs with sync on rmx controller
hi, i run vdj 6.1 and a hercules rmx controller, ive had a few times where when im playing on deck b and load deck a hit cue select and play (to moniter) when i hit sync on deck a it will drag or speed up deck b while it is being play, its happend a few times and the only way to overcme it is to close & re start vdj, has any one else had this problem? if so did you fix it? please help...
geposted Mon 04 Oct 10 @ 6:12 am
Before reporting any issues with the software or controllers - you should ensure that you are running the latest version and can recreate the problem.
You stated that you are using version 6.1 - our current release version is 6.1.2.
You can download and install the latest version from your download center - https://virtualdj.com/download/updates.html
yeh i do have 6.1.2, i cant replecate the fault i was just wondering if any one else has had this issue?
Whats up Dee Jay,
I have seen this fault only when I press play on the 2nd track and I have beat lock on. Now I put beat lock on after Im in the mix and all is well. Then turn it off after I mix out of the 1st track.
ReThink
Cheers Re Think,
your right.. i always have beatlock on and when it happens its the first time i press play on deck b, maybe there is a glitch somewhere the only way i have found to fix it once it happens is to close and restart vdj.... maybe someone has some ideas on how to overcome this prob cause i am sure id forget to do the beatlock on/off as you described at some point and that would be the time it decides to do this ;-)
p.s Re Think, how are you liking the rmx cause i am loving it, i just do mobile work like partys etc, its gettimg its first real run on sat night yay
