Hi everyone. Let me start off by saying that I've visited this site often over the past 10 years and simply love the support I receive. You are a very nice community, unlike some other forums (*cough, serato, cough*)..
Anyway, here's my issue with the numark NS7. It seems like every button and fader works like butter, mapping wise, except I'm not sure how to get the platters to create a wind-down effect when pushing stop. If you press stop, it does just that, stops, which sounds kinda clunky when mixing. Id like to have it make the sound of when you push a stop button on the Technics 1200 turntable. Make sense?
Is there a midi config of some sort that can replicate this?
Thanks in advance.
Thanks in advance.
geposted Mon 04 Oct 10 @ 10:04 pm
Oh, and a side note, yet related question. Does anyone have the FX unit for NS7? Is that playing nice with VDJ?
geposted Mon 04 Oct 10 @ 10:05 pm
Its called the Brake effect and if you want that effect sound when you stop then you need to use it.
geposted Mon 04 Oct 10 @ 10:10 pm
Good advice. Is there a way to midi map an effect like brake? I'm not seeing effects as a config option..
(thanks for the quick reply BTW)
geposted Mon 04 Oct 10 @ 10:28 pm
I have the NSFX and it works great, tons of extra control, thanks to Cstoll's map.
The command you are looking for is:
•effect active : start or stop the effect. you can also specify an effect by name ('effect "my_effect" active on'), or use a different effect slot ('effect 3 active').
The direct command would be:
effect "brake" active
geposted Tue 05 Oct 10 @ 9:14 am
Cheers, mate! Got it to work flawlessly. I'm gonna have to spring for the ns7fx
geposted Wed 06 Oct 10 @ 10:43 pm
Bleep only works as reverse, start time stop time do not work, pitch blend is super slow in reacting, Those are just the things that would make it usable for me. Brake will work for end but the is nothing for a slow vinyl start...
geposted Fri 05 Nov 10 @ 2:23 pm
geposted Fri 05 Nov 10 @ 7:00 pm
I just recently purchased the ns7fx. .great new toy for me. . Im just bumbed out because the turntable start and stop knobs dont work. . I have been looking for something to make them work. . . My thought is using the turntable off button yo activate a plugin called breakstart and usint he turntable start and stop knobs to control the two parameters for the sound effect. . No succes if any one can help me that would be amazing
geposted Tue 29 May 12 @ 4:15 pm
