Forum: VirtualDJ Skins
Topic: Need some help!!!
I got Hercules mk2 that comes with the soft 3.4.1,it's OK but I notice that there are free skins can i pick any of these?? are all compatible with the the software that came with it Feeling lost plz help i just want a different skin that have's all the effects and that looks better then the one that came with the Hercules mk2
geposted Wed 06 Oct 10 @ 8:13 am
2 things, u wanna look at the version the skin was made for right underneath it, and also i think some of the skins are locked and only availablt to ppl who have the pro.
geposted Wed 06 Oct 10 @ 5:40 pm
Thanks for the info..I just check the skins and none of them matches my software i guess I'm stuck with this one..hope somebody makes more skins for people that are not pro yet..
geposted Wed 06 Oct 10 @ 11:26 pm
u cna use any skin you want....just match your skin to the resolution of ur PC screen....the software (VDJ) allows you to remap your controller to match the buttons on your new skin.....enjoy!! =D
geposted Sun 19 Jun 11 @ 12:09 am
