I'm about to purchase a new laptop which will have Windows 7 installed on it, so I just want to check that VDJ 6 runs fine on Windows 7?
No doubt there'll be some people that have run into problems but are the majority finding it OK?
My current setup is on Vista and running version VDJ 5.21
geposted Wed 06 Oct 10 @ 11:20 am
Actually Windows 7 is more friendly to audio applications than Vista. Anyway VDJ6 works flawlessly on Windows7.
geposted Wed 06 Oct 10 @ 11:27 am
I am running Windows 7, 64 bit with the Hercules DJ Control and I have no problems. However it is worth noting that I use VDJ for fun, not as a professional.
Hope that helps
Peace,
James
Hope that helps
Peace,
James
geposted Wed 06 Oct 10 @ 11:39 am
Thanks for the replies guys, I thought that would be the case but just wanted to check.
geposted Wed 06 Oct 10 @ 11:45 am
As above, you'll be fine running on W7 :)
geposted Wed 06 Oct 10 @ 12:57 pm
I have it running on 32 bit and plays much more better vs being on XP (same unit).
In fact, will be rolling out 7 on my gig rigs for 2011.
geposted Wed 06 Oct 10 @ 1:12 pm
wow cool!
geposted Wed 06 Oct 10 @ 1:24 pm
that was ewitles , rush chairman ......
he's gonna have his own version of VDJ 7
as far as i can tell W7 seems to be more friendly to audio and soundcards than Vista and XP
i have 4 systems ....1 XP, 1 Vista , 2 W7 .....
i use the RMX on the Vista and one of the W7's ....getting the Vista system right was a huge pain
for whatever any of that was worth ....
geposted Wed 06 Oct 10 @ 2:56 pm
W7 64 bit with denon 4500 since April min 3 nights a week, for two months it was 7 nights a week, never a problem yet.
geposted Wed 06 Oct 10 @ 3:19 pm
3 laptops runnin win7 home premium..with two numark total controls and one numark dmc2..2 audio2dj and 1 audio4dj soundcards 3 external seagate 1 tb hard discs...all running synchronized through network without any problems...that shows something win 7 32bit is the perfect way to go.
geposted Wed 06 Oct 10 @ 4:18 pm
