Is there a definitive list of supported timecode vinyl and if they support absolute/relative/both? When looking in the timecode setup in the software I can't really tell if each type of vinyl supports absolute mode.
I am coming from FinalScratch timecode and they aren't supported in most modern software so it's time for an update. I also use Deckadance and would like to purchase vinyl that works with both VDJ and Deckadance in absolute mode.
Thanks!
Thanks!
geposted Wed 06 Oct 10 @ 11:50 am
This will not be so easy - because every Timecode System ist developed by the manufacturer of the software. The only soft i know which supports more than it's own system is Virtual DJ.
The recomended Vinyls for VDJ are the one provided with Virtual Vinyl (Numark) or the Noisemap System from Serato.
Greets, Heiko
Greets, Heiko
geposted Wed 06 Oct 10 @ 12:01 pm
