Just wondered whether it's possible to replace the virtual DJ logo with my own logo to show on the screen?
Is this possible and if so how?
Thanks.
Thanks.
geposted Wed 06 Oct 10 @ 11:57 am
No, it's not possible directly, but:
From VDJ Options you can turn off the built-in logo. Then from the plug-ins download area you can download the "Show logo" plug-in that can be used to show your own logo over the video and that it's way more flexible than just replacing the original logo!!!! For instance you can choose to use transparency, you can choose it's size and it's place on the screen, e.t.c.....
geposted Wed 06 Oct 10 @ 12:06 pm
Which VDJ logo, and where?
geposted Wed 06 Oct 10 @ 12:10 pm
The Logo on the video out can be turned off - the one in the skin not.
Greets, Heiko
Greets, Heiko
geposted Wed 06 Oct 10 @ 12:11 pm
Thanks.
Thanks.
Do you mean in VirtualDJ skin or on a 2nd screen showing video files?
For 2nd, you can turn off the logo, in the video options
geposted Wed 06 Oct 10 @ 12:30 pm
Cheers Phantom, this is exactly what I was after.
geposted Wed 06 Oct 10 @ 1:26 pm
here is the direct link to the logo effect :
https://virtualdj.com/addons/2929/ShowLogo.html
geposted Wed 06 Oct 10 @ 1:29 pm
There is another option if you like...
You can use image tab to put a logo or image on screen any where and any size, use the adrotator tab to have a sequence of logos or images running at pre determined intervals, you can then use the template tab to save those settings for the next time you want to use them, it will save you time in having to reset up those files for future use.
Use PNG files for best effect.
You can get the free Firetext plugin in the video effects download section.
Hope that helps.
Hope that helps.
geposted Thu 07 Oct 10 @ 6:58 am
Good effect Tayla.... like so much....
geposted Thu 07 Oct 10 @ 8:17 pm
thanks ro...
geposted Fri 08 Oct 10 @ 5:16 am
How do you post video's here ?
[youtube]http://www.youtube.com/watch?v=OJb8vueXxul[/youtube]
geposted Fri 15 Oct 10 @ 2:47 am
geposted Fri 15 Oct 10 @ 2:54 am
i know a way to replace or remove any logo or start up screen on virtual dj but ill respect whatever decision is made if i can post it or not by any team member...let me know if its ok?
geposted Tue 07 Dec 10 @ 11:16 pm
