Hi all,
I'm trying to use Virtual DJ 6.1.2 in combination with Hercules DJ Console RMX and two StantON T.80 timecodes.
Does somebody has experience with the StantON T.80 and Virtual DJ?
I need to know which mapper i can use, because i tried several of the basic mappers, but they don't seem to work properly.
Thanks in advance.
Thanks in advance.
geposted Fri 08 Oct 10 @ 11:07 am
these videos might be helpful? Good luck
http://www.youtube.com/watch?v=dp6USvPoZ0k&p=4DC26196EE9BCA29&playnext=1&index=1
http://www.youtube.com/watch?v=eYW5PaZnhbs&feature=related
geposted Fri 08 Oct 10 @ 12:07 pm
i dont use the t80 but i use the t.52 waiting to get the str150's but the set up is like the demo said you just run:
out the t80
in the rmx 1-2 switched to phono for table 1
in the rmx 3-4 swiiched to phono for table 2
config settings vdj
inputs timecode
output headphones(since no mixer specified)
soundcard herc
hope that helps
out the t80
config settings vdj
inputs timecode
soundcard herc
hope that helps
geposted Fri 08 Oct 10 @ 12:24 pm
