Hi,
I'm in the process of buying the Pioneer CDJ 400's to use together with VDJ pro 6.1. Can I map a button on the cj 400 to work as the sync button and function so that the software automatically matches the BMP of the songs. This feature is availible on the CDJ 350's which will influence my decission ?
thanks
Pregs
thanks
Pregs
geposted Mon 11 Oct 10 @ 3:26 am
Yes, you can change the mapping of the buttons to any function of your choice.
You can easily map any button of your choice to sync
geposted Mon 11 Oct 10 @ 4:15 am
