How come songs that I deleted from my library show up when I search them? Do I have to uninstall virutal dj and reinstall in to clear it out?
Thanks
Thanks
geposted Mon 11 Oct 10 @ 9:51 am
You have to go into config and then go to the second to last tab I believe (don't have vdj on this comp, work) but you have to do the" check, fix, clean" thing. That should take care of it.
Hope that helps
Huey
Hope that helps
Huey
geposted Mon 11 Oct 10 @ 9:56 am
It's the 'Browser' Tab. There you find the repair, clean and fix option for VDJ.
Greets, Heiko
Greets, Heiko
geposted Mon 11 Oct 10 @ 10:18 am
Hey thanks guys!! I appreciate the help!
geposted Mon 11 Oct 10 @ 10:51 am
also when you get your library sorted the way you want backup your .xml file and do all song changes filename changes ect within vdj
geposted Mon 11 Oct 10 @ 1:17 pm
