Evening all,
Got my usual setup going from my PC to broadcast over the www.
However......
I use the onboard soundcard to run the master, a USB soundcard to run the cue but the addition of a mic for presenting is an issue.
How do I get a mic in the mix?
I had the same prob recording a demo so I had to do the mix then go back and voiceover it after.
Any help would be appreciated.
Cheers
However......
Cheers
geposted Mon 11 Oct 10 @ 4:17 pm
Bump
geposted Tue 12 Oct 10 @ 4:12 am
There is no mic input on the current version of VDJ.
Solution: Use a profession sound card that has a mic input, or use a USB mixer.
geposted Tue 12 Oct 10 @ 4:34 am
OK.
So would it matter if I ran the house of cue from the soundcard that has a mic input? I would have thought that would have the same result if VDJ isn't setup to recognise a mic input from a soundcard?
Thanks
Thanks
geposted Tue 12 Oct 10 @ 6:12 am
Check the releasenotes on V7..... Your answer is there ;)
geposted Tue 12 Oct 10 @ 6:44 am
checkout the new user guide for v7....
geposted Tue 12 Oct 10 @ 8:01 am
Checked out. Marvelous.
Any recommendations for an ASIO card to do the job for under £70?!
geposted Tue 12 Oct 10 @ 9:01 am
On the other hand, my UCA202 did the job. Can I not just get another like it with a mic input? It was only £20!
geposted Tue 12 Oct 10 @ 9:48 am
Whilst we're (or maybe just "I'm") on the subject:
http://www.google.co.uk/products/catalog?q=7.1+usb+soundcard&hl=en&cid=13841318541091473988&ei=RYS0TLWUJoLI2ATIj9SmCQ&sa=title&ved=0CAcQ8wIwADgA#p
Anyone ever used one of these broadcasting, or at gigs?
geposted Tue 12 Oct 10 @ 10:59 am
seems very cheap ? no windows 7 ........
geposted Tue 12 Oct 10 @ 12:52 pm
Not on Windows 7
geposted Tue 12 Oct 10 @ 5:23 pm
