Eh ben voilà, on l'attendait tous, là voilà la nouvelle version :-D
Features :
Multi Deck:
support for up to 99 decks
include skins for 4 and 6 decks
support both true multi-deck logic or mini-decks with left/right zoom logic
Audio:
new Advanced Audio Config panel with line by line configuration
Line-in/Mic support with effects, waveform display, beat-matching
Instant record of Line-in or Mic for replay and scratch
Rewire support
new master tempo engine
new PureScratch engine
low-latency audio on Vista and Win7 when using Advanced Audio Config
new built-in resonant filter on each decks
Database Management:
new GenuisDJ algorithm
new FileInfo window with multi-files tag and rename
save to ID3 tags (or mp4 tags) option
new browser fields (composer, rating, custom fields)
support for nested virtual folders
easy drag-n-drop management of virtual/favorite/smart folders
automatically renew and manage Netsearch DRMs before it expires
new zoom mode for temporary fullscreen browser
new integrated audio preview of browsed songs
Video engine:
improved H.264 decoder
new overvideo action for multideck configs
access to more than 2Gb of memory on Vista and Win7
Record and Broadcast:
Video codec list for video record (on PC)
support for ICECAST2 broadcast
record loopback and mic recording are now set in the Advanced Audio Config
Controllers:
Plug-and-play support for more than 80 controllers
support Hot-plug and unplug of controllers automatically
Skin engine:
<panel visible="VDJScript">
<element os="mac">, <element os="pc">
<text format=""> can use execution (`) operator (<text format="Deck `get leftdeck`">)
skin engine can parse mathematical expressions in the xml: <pos x="42+3*500" ...>
<init action="...">
<rhythmzone> (like <rhythm> but new simpler syntax based on color values instead of images, see the default 4deck skin for examples)
can have multiple <browser> in panels
can use <center x="" y=""> instead of <pos x="" y="">
improved font replacement on Mac
VDJScript:
new action "get text" with unix-style execution operator (inverted quote): ` (get text "The filesize is `get filesize`, playing is `play` and volume is `volume`.")
new actions "get loaded_song 'column' ", "get browsed_song 'column' ", "get automix_song 'column' " where column is the name of the browser column (see <columns> in Languages/english.xml for the list)
new/modified actions: "play_sync", "play_onbeat", "play_sync_onbeat"
can use cue names instead of numbers in "got_cue", "set_cue", etc...
many new actions, see Languages/english.xml for the complete list
Morpheo
Features :
Multi Deck:
Audio:
Rewire support
Video engine:
Controllers:
Skin engine:
<init action="...">
VDJScript:
Morpheo
geposted Tue 12 Oct 10 @ 5:44 am
elle va faire tres mal.
rien qu'avec un petit test vite fait,je vous l'affirmes :))).
geposted Tue 12 Oct 10 @ 6:06 am
je viens de la testé 5 mn (je pars au taff :(...)elle est excellente faites attention la v6 reste la 7 ne passe pas au dessus, la skin 4 decks et excellentes j'adore ;)
un grand bravo a la team pour se travail :)))
Je ferme le sujet, veuillez utiliser celui-ci pour discuter de la v7:
https://virtualdj.com/forums/135503/French_Forum/_New__VirtualDJ_7.html
