ça y est il est arrivé la version 7.0 au Centre de téléchargement.
Multi Deck:
support for up to 99 decks
include skins for 4 and 6 decks
support both true multi-deck logic or mini-decks with left/right zoom logic
Audio:
new Advanced Audio Config panel with line by line configuration
Line-in/Mic support with effects, waveform display, beat-matching
Instant record of Line-in or Mic for replay and scratch
Rewire support
new master tempo engine
new PureScratch engine
low-latency audio on Vista and Win7 when using Advanced Audio Config
new built-in resonant filter on each decks
Database Management:
new GenuisDJ algorithm
new FileInfo window with multi-files tag and rename
save to ID3 tags (or mp4 tags) option
new browser fields (composer, rating, custom fields)
support for nested virtual folders
easy drag-n-drop management of virtual/favorite/smart folders
automatically renew and manage Netsearch DRMs before it expires
new zoom mode for temporary fullscreen browser
new integrated audio preview of browsed songs
Video engine:
improved H.264 decoder
new overvideo action for multideck configs
access to more than 2Gb of memory on Vista and Win7
Record and Broadcast:
Video codec list for video record (on PC)
support for ICECAST2 broadcast
record loopback and mic recording are now set in the Advanced Audio Config
Controllers:
Plug-and-play support for more than 80 controllers
support Hot-plug and unplug of controllers automatically
Skin engine:
<panel visible="VDJScript">
<element os="mac">, <element os="pc">
<text format=""> can use execution (`) operator (<text format="Deck `get leftdeck`">)
skin engine can parse mathematical expressions in the xml: <pos x="42+3*500" ...>
<init action="...">
<rhythmzone> (like <rhythm> but new simpler syntax based on color values instead of images, see the default 4deck skin for examples)
can have multiple <browser> in panels
can use <center x="" y=""> instead of <pos x="" y="">
improved font replacement on Mac
VDJScript:
new action "get text" with unix-style execution operator (inverted quote): ` (get text "The filesize is `get filesize`, playing is `play` and volume is `volume`.")
new actions "get loaded_song 'column' ", "get browsed_song 'column' ", "get automix_song 'column' " where column is the name of the browser column (see <columns> in Languages/english.xml for the list)
new/modified actions: "play_sync", "play_onbeat", "play_sync_onbeat"
can use cue names instead of numbers in "got_cue", "set_cue", etc...
many new actions, see Languages/english.xml for the complete list
Multi Deck:
Audio:
Rewire support
Video engine:
Controllers:
Skin engine:
<init action="...">
VDJScript:
geposted Tue 12 Oct 10 @ 5:45 am
Tu as été devance sur l'info
geposted Tue 12 Oct 10 @ 5:47 am
lol et limol par moi.
notre modo préférer aura un peu de boulo comme ça ;)
edit: terribleeeeeee
test effectuer sur un pc de b*** avec 1 G de ram et une carte graphique de nul (simple pc de bureau)
cela tourne grave sur cette configue et le cpu n'est plus a fond.
je vais vite le mettre sur deuxième pc (la bete de course ;) ),celui dédier au mixe :))
geposted Tue 12 Oct 10 @ 5:48 am
je viens de la testé 5 mn (je pars au taff :(...)elle est excellente faites attention la v6 reste la 7 ne passe pas au dessus, la skin 4 decks et excellentes j'adore ;)
un grand bravo a la team pour se travail :)))
geposted Tue 12 Oct 10 @ 6:07 am
Grosse, grosse nouvelle !!!
Quand je vois le descriptif, j'ai hâte d'être à ce soir.
Avec tout ce qui est maintenant affichable à l'écran, mon 17 pouces va être trop petit. mdr
Merci pour cet énorme mise à jour !!!
geposted Tue 12 Oct 10 @ 6:09 am
Hé ben ...
Vous êtes rapides les gars. Speedy Gonzales est une tortue à coté de vous.
En tous cas c'est une très bonne nouvelle. Vivement ce soir.
Rendez-vous demain pour nos premières expériences avec cette nouvelle mouture.
geposted Tue 12 Oct 10 @ 6:23 am
Super sympa ! Merci Atomix Prod. !
Je suis sur mon iPhone, en cours, je viens faire un tout sur le Forum (Normal) et je vois la sortie de la v7.
Les test ça sera ce soir pour moi !
Juste vous savez si sous Mac ça écrase la version precedente ?
Peace
DJ-Spark
Peace
DJ-Spark
geposted Tue 12 Oct 10 @ 6:47 am
Salut à tous ;)
Tres bonne surprise que de retrouver le mode REWIRE dans cette nouvelle version, là je pense que VDJ a fait un jolie bond en avant!!!
Ont va pouvoir ENFIN mixer avec nos instrus externe et/ou avec notre sequencer favorie, et ça, c'est une TRES BONNE CHOSE!!!!!
Le moteur audio apparement, a était refait (Et c'est tant mieux).
Je vais tester cette nouvelle version plus en profondeur et je reviendrais faire part de mes autres sentiments plus tards, en tout cas, c'est un bon debut ;)
geposted Tue 12 Oct 10 @ 6:55 am
Question !!! La 7 doit être installé par dessus l'avant dernière version ou doit on desinstaller ? Pour ma part en re installant par dessus cela me rajoute une 2eme icone VDJ .......
geposted Tue 12 Oct 10 @ 7:10 am
c'est normal pareil chez tout le monde ;)
tu auras la 6 et la 7 :))
geposted Tue 12 Oct 10 @ 7:11 am
Etant donné la nouvelle gamme de produit, nous avons du distinguer le nom de chaque exécutable. On a donc même coup décidé de laisser l'ancienne version.
geposted Tue 12 Oct 10 @ 7:18 am
Par contre il y a aussi des points positifs,le son m'as lair plus propre(ENFIN) et wha sa m'as l'air stable,le cpu monte moins(1 peux) et la forme d'onde est bien plus propre et stable,a esperer que le probléme de l'affichage de la platine 2 soit vite resolue,parceque juste comme sa sa a pas l'air d'inquieter les modos,a croire qu'il faut juste dire du bien de cette new version,BEN NON!!!je dis ce qui est positif mais egalement le probleme que je rencontre,sa me parait legitime et normal!!!Bon pour etre honnéte a part ce probléme d'affichage,pour le reste cette new version est vraiment pas mal,et je parle pas des 99 decks sa ne m'i,nterresse pas du tout,je parle de tout le reste,vraiment pas mal!!!
geposted Tue 12 Oct 10 @ 7:26 am
Après essai, je ne peux pas utiliser les filter, j'ai un "erreur dans le fichier xml".
Après deux petites questions:
-J'ai un horrible phasing quand j'utilise l'overloop, c'est normal? car ça le rend inutilisable.
- [HS] Il y a un moyen d'éditer des marqueurs sur les titres afin d'envoyer à certains moments une commande midi, dmx, soit sur le pc (vers un soft) ou en externe? et noter des infos, comme avec les cue, sans pour autant tomber dessus dès qu'on charge le titre ou en appuyant sur stop?
(et oui, un revenant sur le forum!)
geposted Tue 12 Oct 10 @ 7:30 am
Je viens de tester pendant 1h et merci la team pour cette version.
Je vais pouvoir m'amuser avec 4 decks et ableton avec le REWIRE.
Super le mode fullscreen pour le browser car j'utilise rarement le reste de l'affichage...toutes les infos dont j'ai besoin se trouve sur mes platines.
Super aussi le nouveau master-tempo et les différentes résolution pour la skin VDJ7.
J'ai une grosse soirée ce samedi, on verra ce que ca donne après + de 10h de mix.
Merci d'avoir séparer l'exécutable de VDJ avec celle de la version précédente. En cas de problème en soirée, je pourrai revenir sur l'autre version.
geposted Tue 12 Oct 10 @ 7:41 am
En tout cas un grand bravo à la Team sur le nouveau moteur audio :-) fini les soucis d'avant meme sur PC tres bon ce master tempo.
MERCI LA TEAM POUR LES AMELIORATIONS
geposted Tue 12 Oct 10 @ 8:14 am
Pareil pour la qualité son !!!!!! Grandement améliorée.......
Avons nous une info pour comment utiliser les 4 decks ??
geposted Tue 12 Oct 10 @ 8:19 am
Tout est expliqué dans le fichier VirtualDJ 7 - Audio Setup Guide.pdf
geposted Tue 12 Oct 10 @ 8:20 am
Hello ! Bravo ! Super ! (etc ... etc...)
Après les premiers bidouillages pour tester la bête avant samedi, j'ai un seul et unique petit problème : le basculement CD / Vynil pour modifier le comportement des Jogs fonctionne pour les decks 1 et 2, mais visiblement pas pour les decks 3 et 4 qui ne se comportent qu'en mode scratch. Y'a-t-il une astuce pour remédier à ce soucis ?
geposted Tue 12 Oct 10 @ 8:27 am
il manque ici : http://www.virtualdj.com/wiki/PDFManuals.html à titre d'information ,-)
geposted Tue 12 Oct 10 @ 8:29 am
Coucou,
savez vous si elle est supportée par win 7 64bits et par les proc i7 quad core?
Le mode natif des cdj 2000 affiche t'il les pochettes d'album et la wave form?
Merci
Merci
geposted Tue 12 Oct 10 @ 8:37 am
