I just set a single timecode configuration with the mp3e2 as internal mixer to try the new vdj7
how could I set the single timecode to deck B, I use the right hand and i need the turntable to be on the right, i looked everywhere and I can't find how, am i wrong?
anoyne knows?? please help
geposted Tue 12 Oct 10 @ 11:06 am
Your timecode should control whatever deck is active. You can use the [tab] button on your keyboard to toggle which deck is active.
geposted Tue 12 Oct 10 @ 11:13 am
i tried to press tab but only changes the pfl on the deck, the turntable with the timecode controls deck A only and the B is controlled by the mp3 e2 how could i switch???
geposted Tue 12 Oct 10 @ 11:56 am
Try mapping a button with this,
"deck 1 timecode_active & deck 2 timecode_active"
Hope that helps
Huey
Hope that helps
Huey
geposted Tue 12 Oct 10 @ 1:14 pm
YEEEEESSS!!! it worked, thanks a lot man!
peace
peace
geposted Tue 12 Oct 10 @ 3:33 pm
