I had one button set as loop_button.
Press once for loop in, twice for loop out; and the
third to exit. It worked for one day.
Now it will only give me a 2 beat loop.
Also it sometimes just goes a bit crazy and I get this
showing on the screen < >.
I even used different buttons to see if one of the buttons
might be bad. No luck.
I reverted to the original settings, and it is the same.
Any ideas please?
Any ideas please?
geposted Tue 12 Oct 10 @ 12:45 pm
Loop_button works here !
Syntax: deck 1 loop_button or deck left loop_button
<> means Smart Loop is not enable. Assign a keyboard shortcut with action="smart_loop" if you want a seamless loop.
Which skin are you using?
geposted Tue 12 Oct 10 @ 9:16 pm
Thank you.
I tried the smart_loop. It did not work.
Did the loop_button. That's when it went a bit crazy.
It would only allow 2 beat loop.
I am going to delete the mapper completely, and re try.
geposted Wed 13 Oct 10 @ 10:44 am
If you want to get rid of the <> sign, assign a keyboard shortcut with loop 4, then activate the smart loop, and then you can use your loop_button without any <> in the future.
geposted Wed 13 Oct 10 @ 2:07 pm
Deleted the mapper completely and re entered it.
So far seems ok .
Many thanks.
So far seems ok .
Many thanks.
geposted Thu 14 Oct 10 @ 7:27 am
