Excuse me for the naive question, but where is the master output on hercules rmx controller ( the output that you connect your speakers to )
geposted Tue 12 Oct 10 @ 2:14 pm
hope this is what your after...
geposted Tue 12 Oct 10 @ 5:46 pm
It did help thanks for the picture, but I was wondering... isn't the rmx also a mixer? or do I have to have a separate mixer with rmx?
geposted Tue 12 Oct 10 @ 5:56 pm
Ch 1&2 Outputs is the master. Ch 3&4 are bounded to headphones output.
The diagram may confuse you but the Audio Setup Config is correct.
geposted Tue 12 Oct 10 @ 7:40 pm
it does confus me, Now I am thinking about getting a mixer, and a Rackmount Controllers like Numark DMC2 or Denon HC4500, (which would you recommend btw) I am a complete naive at djing so something not to expensive will work too. What mixer would you recommend for beginners, or if its possible to hook up rmx to master speakers without mixer that would also work too. :)
geposted Tue 12 Oct 10 @ 8:11 pm
