TC mania one of your favorite skins, is 4 decks now
TCmania 4Decks
TCmania 4Decks
![](/image/95544/44102/TCmania 4D Image large.png)
geposted Tue 12 Oct 10 @ 3:42 pm
Uploaded and soon available
http://www.virtualdj.com/addons/12084/TCmania_4Decks.html
Resolution 1440X900
Resolution 1440X900
geposted Tue 12 Oct 10 @ 3:44 pm
TCmania 4Decks is clearly a True Deck Skin (no left right logic), meaning that you can actually mix ANY decks !
It is suitable for users with multi channel mixer and sound cards, with multiple decks and controllers.
2 different main panels (screens)
2Decks
![](/image/34796/44109/TCmania4d2decks.jpg)
4 Decks
![](/image/91005/44110/Tcmania4d4decks.jpg)
2Decks
4 Decks
geposted Tue 12 Oct 10 @ 3:59 pm
6 different center (mixer) panels
3 for 2Decks Mode & 3 for 4Decks Mode
(new Mute buttons for the 4channel mixer)
![](/image/75678/44113/Tcmania4dmixers.jpg)
geposted Tue 12 Oct 10 @ 4:09 pm
New Revolutionary Rhythm View
In case of true deck skins, where no left & right decks excist, all you need to view is the Selected Deck and the Masterdeck (OnAirDeck)
So in TCmania 4D this is happening ! You will view on the top the Masterdeck and on the bottom you will view the Selected. Each time these change,the Rhythm changes also !
![](/image/49226/44114/Tcmania4drhythms.jpg)
geposted Tue 12 Oct 10 @ 4:15 pm
Small pannels are also available for Each Deck.
Loop & Effect remain steady, the others are selectable.
![](/image/25755/44117/TCmanis4dminipanels.jpg)
New Resonant Filter has ON-OFF button just to make sure is OFF.
![](/image/8488/44119/TCmania4dfilter.jpg)
geposted Tue 12 Oct 10 @ 4:35 pm
I love the TCmania skin (it is what I have been using for awhile now) but when I tried to open this version after using the resizer tool on it (to 1280x800) it crashed and gave this report:
Crash ID=004a1371 (date=1010121854, version=7.0 Pro, build=342, thread=Main, dump=891983c2, excode=c0000005 (1,7f37524))
any help in this matter would be great cause I LOVE this skin and would love to use it for VDJ7 and 4 decks. Thanks in advance.
Michael
Michael
geposted Tue 12 Oct 10 @ 5:58 pm
I cant guarantee for any results that are related to the Skin Resizer. Please post this to the Skin Resizer Topic.
Propably something with the new Rhythm Zone syntax or the Multiple Browsers which as far as i know Skin Resizer doesnt support.. I had similar issues when i tried to resize it. It has nothing to do with the skin itsself. I guess if you try to run the original resolution you have no crashes...correct ?
geposted Tue 12 Oct 10 @ 7:09 pm
dj dad?
are you planning to do a 1280x800 or 1366x768 of your amazing skin.?
geposted Tue 12 Oct 10 @ 8:28 pm
1366X768 (16:9) is certainly in my plans.
geposted Tue 12 Oct 10 @ 9:07 pm
that would be fantastic man my lap use that resolution 1366x768. I'LL be waiting for it. thanks DJ dad
geposted Tue 12 Oct 10 @ 10:00 pm
Fantastic, I use your skin since many month now. I use a 1920x1200 resolution. Do you planed to make it one ?
geposted Wed 13 Oct 10 @ 3:31 am
Hi
coult you please built the skin in 1680x1050 and 1280x800
Many Thanks
chris
Many Thanks
chris
geposted Thu 14 Oct 10 @ 2:55 am
1680x1050 would rule!
And might be a very good alternative to the Condensed that I am using.
It looks very 'complicated' to the average guest. :)
geposted Thu 14 Oct 10 @ 1:04 pm
..but you are not one them right? lol
geposted Thu 14 Oct 10 @ 2:16 pm
Well, Serato looks simple (no offense) and the old style PCDJ was very simple.
But from the nosy guest perspective, a complex skin is almost akin to having cases of amps n gear. Removes the consumer aspect a bit. :)
geposted Thu 14 Oct 10 @ 2:19 pm
but it gives you the WOW factor, lol.
Michael
Michael
geposted Thu 14 Oct 10 @ 3:28 pm
It's Good
geposted Fri 15 Oct 10 @ 6:50 am
following my past post. 1920x1080 is also a great resolution since my laptop use it ;-)
geposted Fri 15 Oct 10 @ 7:43 am
Quick question, is there a way that I can keep all the "beat" waveforms at the top visible like on the VDJ screen instead of them vanishing? I love the skin but with waves vanishing it kinda throws me off sometimes. Thanks for the help. (and thanks for helping me with the resize issue as well.)
Michael
Michael
geposted Sat 16 Oct 10 @ 1:06 am
