I loaded in VDJ7 and went to change a tag and chose apply and ok... will not exit this screen no matter what I do. I try to end the program and nothing happens.
This is on my new iMac.
What other info do you need?
Scott
Scott
geposted Tue 12 Oct 10 @ 4:06 pm
Update... it will exit the screen... sorry but it will never go back to the main VDJ screen.
Similar Problem, loaded once but now always stalls at initialising external devices, then can't even force quit it. Forced to shut computer down. (VDJ 7 Home).
geposted Tue 12 Oct 10 @ 4:09 pm
Does the window actually go behind the skin?
geposted Tue 12 Oct 10 @ 4:36 pm
Jason,
Not really... the screen shows only the background. If I click on the background, it brings back the tag screen. I will shoot you a screen shot later.
Another problem...(possibly a larger issue) I can not exit VDJ. I have tried several times and it simply won't close down. Almost as if the control Q is not assigned. It does not close by using the drop down either.
What else do you need to know Jason?
Thanks for your help with this.
Scott
Scott
geposted Tue 12 Oct 10 @ 5:21 pm
Confirmed the same on 2 different Macbook Pro's and 1 iMac... not sure if you needed to know that but just in case.
geposted Tue 12 Oct 10 @ 5:22 pm
Am I the only one with this issue? (thats never good)
geposted Wed 13 Oct 10 @ 8:15 am
Same here, quitting using Option + Q doesn't work, but red "traffic light" button works fine.
geposted Wed 13 Oct 10 @ 9:05 am
Okay, thanks for confirming.. obviously not too many mac users with this problem...
I am sure the VDJ folks will get us a fix very soon.
Scott
Scott
geposted Wed 13 Oct 10 @ 4:06 pm
I'm happy, CMD + Q does not close VDJ.
I often use CMD + TAB to switch between different programms and sometimes i hit the wrong key, lol!
But this is only my choice ;-)
It's just a smal bug, but you can't delete a complete playlist.
If you try to delete, you will see it is still there.
Also if you delete a track, or the track is not longer in the path you saved them in the playlist, the track appears as present not as unknown, like in the Windows Version.
So don't worry, if a error occurs.
Try to serach for the Track and load it.
For me, the actual build is the best ever!
Love it!
Love it!
geposted Thu 14 Oct 10 @ 2:34 am
