Hey everyone
I haven't used VDJ in a while... What does this skin re size feature do?
Does it mean I dot have to create a skin for the size of
My resolution?
My resolution?
geposted Tue 12 Oct 10 @ 4:20 pm
geposted Tue 12 Oct 10 @ 5:05 pm
i know what/how to use the skin resizer tool...
what does this feature do that was added in VDJ 6.0.7 :
automatically select best skin fitting your screen resolution
geposted Tue 12 Oct 10 @ 10:00 pm
ah yes.. vdj will auto select best fitting skin at first run.
Also, you can drag from bottom corner of the skins, to resize the window
geposted Wed 13 Oct 10 @ 1:56 am
