Forum: VirtualDJ Skins
Topic: TCmania 3 Decks (Right handed version)
TCmania Skin Family has a new member !
TCmania, TCmaniaBright, TCmania4Decks and now TCmania 3Decks !!!
Download Link https://virtualdj.com/addons/12085/TCmania_3Decks.html
Resolution 1440X900
No Pannels this time LOL !!! (Just the 3 basic center)
All the features you need in just 1 screen !
3 True Decks, 3 channel mixer
This is a righthanded user verion with 2 Decks on the right side of the mixer and 1 deck on the left side. There will be also a lefthanded vrsion soon !
geposted Tue 12 Oct 10 @ 5:01 pm
any possible way you can make this ata 768 resolution? if you can let me know. I like the simplicity of this and 3 decks would work beautifully with my current set up.
The skin does not have multiple browsers so Skin Resizer will do your job at any resolution.
thumbs up!
que tengo que hacer para tener estyos sking
these skin or more you can download if you have a orginal licence of virtual dj
ese skin o mas lo puedes descargar si tienes una licencia original de virtual dj
https://virtualdj.com/buy/
please don´t write in these forum in spanish try to go at the spanish forum for more information
por favor no escribas en este forum en español, intenta ir al forum en español para mayor informacion
How about a left handed version??
Just asking ;-)
Huey
mercii
i need to have the bpm button of each channel. is there any hidden way in the skin to reach this function?
Nope, BPM edit was forgotten :)
But you may easily edit the skin (xml file) and add that as rightclick on the BPM value on each deck.
Unzip the skin file. Open the xml file with some Text Editor (e.g. Notepad). Search for Pbpmex. You will find 3 elements (parts) in the skin each one for each deck , and you have to add the bold letters to each one of them , changing thee deck number of course.
<textzone deck="1" rightclick="deck 1 edit_bpm">
<pos x="290" y="242"/>
<size width="71" height="22"/>
<text font="arial" size="22" color="WHITE" align="right" format="%Pbpmex"/>
<text2 font="arial" size="22" color="#A0A0A0" align="right" format="%Pbpmex"/>
<text3 font="arial" size="22" color="#1c5381" align="right" format="%Pbpmex"/>
<text4 font="arial" size="22" color="#009edb" align="right" format="%Pbpmex"/>
</textzone>
Save the file, update the zip, and you re good to go.
PS. The above part is from the 1440x900 file. Other resolutions may have different values.
this screen at 1080 would totally rock. i am looking for a functional 3 deck skin (not 4 deck).
won't use 4 deck until there is true wdm multichannel support beyond 3 decks.
