Hi everybody,
I'm just curious... I have tried countless skins, and I would like to hear both decks through my headphones, but the skins only limit me to one deck only.. is there a way to fix this?
Thank you
Thank you
geposted Tue 12 Oct 10 @ 5:19 pm
first I should ask are you using a controller? and secondly, there is a knob or slider at the top of most skins that you can turn or slide that will basically crossfade between mix and cue mode and if you put it in the middle...well you get the idea.
Michael
Michael
geposted Tue 12 Oct 10 @ 6:07 pm
