Let me just start off by saying VDJ 7 is amazing you did a great job atomix no company is supporting as you guys. Now the problem I found is not that big of a deal and it does not really effect me because I use the advanced stretching sound engine setting but if I put it on fast stretching while keylock is on there is a real bug at least for me with the sound engine. It seems I get a horrible distortion with vdj if I move the pitch fader while keylock is on and it is on the fast stretching algorithm. But this isnt a huge issue I just feel atomix should no about this issue, but then again it could just be me that effects only also. I have tried this with my computer sound card and my ns7 sound card though and have gotten the same results. I uploaded a quick sample to sound cloud to further show you what I mean. Again thank you for 7 and your guys's time keep up the good work.
http://soundcloud.com/djanimator/distortion-7/
geposted Tue 12 Oct 10 @ 10:28 pm
yes. the fast master tempo stretching is for small pitch changes..
And depending on soundcard and latency it might sound bad at big pitch changes..
Hence, use advanced stretching for that ;) as you pointed out.. sounds good :)
geposted Tue 12 Oct 10 @ 10:40 pm
that was at a 4bpm change though I guess that is a lot though so its all good
geposted Tue 12 Oct 10 @ 10:45 pm
