Downloaded the latest and greatest tonight, however was let down when I attempted to operate either 4 or 6 deck skins. It said XML error line 31 and wouldn't let me open. Works with 2 decks, but nothing more. Any advice?
geposted Wed 13 Oct 10 @ 12:55 am
You are running VDJ7, not VDJ6 aren't you? They have different shortcuts...
geposted Wed 13 Oct 10 @ 4:22 am
I am having similar problems.. windows 7 pro, installed version 7 twice, when attempting to load the vers 7 skins, the mapping is all wrong on the 2 deck skins and the 4 and up don't load at all.
I'm assuming the Version 7 verbs aren't being recognized.
Also noticed that the version number under help and boot screen still sat ver 6.1.2
Going to do an un-install / re-install and see if that helps.
DjChuck
DjChuck
geposted Wed 13 Oct 10 @ 5:40 pm
It's because you are using the wrong shortcut ... use the one labled -> VirtualDJ PRO
geposted Wed 13 Oct 10 @ 5:48 pm
