I have had a problem with the bpm changing on random video's, I am using the vdj version 4 full video skin or the multi2 skin, where the automix or mix button is at the top in the centre and when you press it you can mix from deck to deck.
I load a video in deck A and it is playing then load one in deck B ready to play, if the the pitch slider is up or down it re-sets to zero cause I have it set to re-set pitch on load.
When deck A has finished and I am ready to manually press the mix button at the top in the centre, once I press it on random video's the pitch slider drifts up or down trying to match the pitch of the video just played. I have tried every setting under the sun to stop this happening, I have tried all version 5's, 6's and now 7, I have tried XP, Vista and windows 7 and it still happends.
The only version where is doesn't happen is version 4.3 using XP, but I have paid for virtual dj and want to be able to use the latest version with the netsearch but I have no confidence in this software with the later versions.
You can be doing a gig and have the dance floor full, mix to the next song and the slider goes down so the music starts playing slow, you hit zero on the slider and the pitch slder starts to move back to zero, but it can take up to 10 secs to sort it's self out and then you look and the dancefloor is empty, It's a nightmare!!! I can't believe that no one else is having this problem.
Any help would be much appriciated, even if it is a bug in the program, then I can stop searching for an answer!!
Many thanks
billy24
Many thanks
billy24
geposted Wed 13 Oct 10 @ 3:45 am
Are you using timecodes? Thats about the times I started noticing timecode drift- around version 4.3.
-David
-David
geposted Wed 13 Oct 10 @ 10:14 am
No I am not using time code, I have put a ticket in and virtual dj team think it may be because I am using and older skin on the latest software and are looking to see if there is an older skin compatable with the new software
geposted Thu 14 Oct 10 @ 2:17 am
