First off....I LOVE version 7. My fiance gave up on me last night and went to sleep because I was GLUED to it. But I ran into one issue.
I used the advanced config and used Decks 1 & 2 for timecoded use with my NI Audio4DJ...Had the inputs for those running as Audio4DJ (ASIO), deck 1 was 1&2, deck 2 was 3&4...Output for those was set for deck 1 to 1&2 and deck 2 to 3&4.
I then wanted to use my Hercules MK2 for decks 3&4. I wanted deck 3 to come out of channel 1&2 on the MK2, and deck 4 to come out of 3&4. It never worked that way. The closest I got was having both decks 3&4 coming out of output 1&2. I wanted to separate them so that each could have its own channel on my DDM 4000. Any idea what I may have done wrong?
EXTENDED question:
In addition to that, I wanted the sampler to be routed to the internal sound card, and use the headphone jack to route the samples to my audio mixer. Every time I added that to the above config, I got ASIO errors.
Is what I'm trying to accomplish possible?
Specs:
HP dv6235us laptop
1.6 ghz processor
2 GB RAM
NI Audio 4 DJ
Hercules MK2
EXTENDED question:
Specs:
HP dv6235us laptop
1.6 ghz processor
2 GB RAM
NI Audio 4 DJ
Hercules MK2
geposted Wed 13 Oct 10 @ 9:26 am
I am beginning to chalk this up as a limitation of the MK2..I haven't used it in QUITE some time..I dusted it off simply for the extra 4 in 4 out sound card, thinking I could run all 4 decks to a separate mixer channel on my DDM. I was thinking of either buying another Audio4DJ or an Audio8DJ, but was trying to hold off...Should I be re-thinking that now?
geposted Wed 13 Oct 10 @ 1:53 pm
hi! i would to ask for some help since you are also running your vdj with an audio4dj soundcard.
what is the best settings that i could use to get rid of those hiccups, i am using serato vynils and my vdj is set in default. i already have game booster installed on my hp laptop but still, it freezes and hiccups occurs sometimes.
thanks in advance!
geposted Wed 20 Oct 10 @ 12:16 pm
The thing that did it for me was increasing the latency and disabling my wireless adapter.
geposted Thu 21 Oct 10 @ 5:46 am
