Hello!
How can i map the jogwheels of rmx controller for deck 3+4 to cd mode!!!They are alway in vinyl mode.No matter how the deck`s 1+2 are mapped!Scratchbutton not aktiv for deck 3+4??thanks
geposted Wed 13 Oct 10 @ 5:43 pm
a simple solution arrived from italian forum is to set jogwhell mode on "CD" ;)
geposted Wed 13 Oct 10 @ 6:41 pm
Discotronic,
How did you setup your "Scratch" button so that it will toggle between all 4 decks? I use the Hercules Control Steel for my controller by the way.
geposted Wed 13 Oct 10 @ 10:07 pm
HACKID wrote :
It is on cd man!But only for deck 1+2!!!3+4 still in vinyl mode :-(a simple solution arrived from italian forum is to set jogwhell mode on "CD" ;)
geposted Thu 14 Oct 10 @ 11:09 am
djrxmx wrote :
It works only for the first 2 decks!!For 3+4 not working.Discotronic,
geposted Thu 14 Oct 10 @ 11:10 am
I just added Deck 3 and 4 to the list in the mapper so its:
deck 1 vinyl_mode & deck 2 vinyl_mode & deck 3 vinyl_mode & deck 4 vinyl_mode
only problem is that deck 3 and 4 are inverted, when scratch is active on 1 and 2 its off on 3 and 4 and vice versa, need to sort that and then its perfect. Need a global command for on and off for all decks.
geposted Thu 14 Oct 10 @ 12:11 pm
discotronic wrote :
Hello!
Discotronic,
If I may comment. I FEEL YOUR PAIN.
No really, I was pulling my hair out last night trying to avert this issue.
I have read so many posts thus far, and I still haven't found a streamlined fix.
I wish the release of version 7 had this worked out beforehand. And it's irritated to see advertisements of the new RMX hardware designed specifically for version 7, when I just got my Control Steel less than 4 months ago.
Rick
geposted Thu 21 Oct 10 @ 4:48 pm
So this tread does not get out of hand, DJ Rxmx found some answers to his questions which might be helpful for others:
https://virtualdj.com/forums/136256/General_Discussion/Loyal_Pro_user_impressed_with_Version_7_features_-_Too_bad_Hercules_wasn_t_better_informed.html
geposted Fri 22 Oct 10 @ 6:26 am
djrxmx wrote :
Discotronic,
Rick
discotronic wrote :
Hello!
Discotronic,
Rick
Maybe the next release will fix this!!;-)
geposted Sat 23 Oct 10 @ 4:26 am
Here the fix!!!:Map scratchbutton with this:
deck 1 vinyl_mode on ? deck 1 vinyl_mode off & deck 2 vinyl_mode off & deck 3 vinyl_mode off & deck 4 vinyl_mode off : deck 1 vinyl_mode on & deck 2 vinyl_mode on & deck 3 vinyl_mode on & deck 4 vinyl_mode on
geposted Thu 11 Nov 10 @ 4:45 am
