I was playing with 7 and so far everything is great, but i've come across something maybe I've missed in the past or have just never needed to know.
When I have 2 Decks playing (say deck 1 and 4) at a time and i want to start an automix of my playlist (say 4). The program starts the automix on Deck 1. Is there a way to tell it what deck i want the automix to start on. The only way i can figure out how to get it to start on 4 at that point is to stop deck 1 and then hit automix while deck 4 is playing then start deck 1 again. I just chose these decks as an example as it could be any combination.
Thanks Guys!
Thanks Guys!
geposted Wed 13 Oct 10 @ 9:12 pm
it starts on the ACTIVE deck :)
in your 4 deck skin, each deck as a number in a round button. :) click 1-2-3 or 4 to set ACTIVE deck.
Automix will start on the active deck selected
geposted Wed 13 Oct 10 @ 11:33 pm
except it doesn't work that way. i just tried loading a song in deck 1, 2 and 4 and then automix the deck. I played them in numerical order. 1 then 2 then 4 and 4 was highlighted as my active deck but it automixed on deck 1. I stop deck 1 and leave deck 2 and 4 running and it then automixes on 2 - with 4 still being my active deck. It seems to always default to the deck that started playing first. I would love it if it actually functioned the way you said it does - on the active deck.
geposted Thu 14 Oct 10 @ 8:12 am
@ dj-in-norway
He's right. Just tested this and Automix loads on the MASTERDECK not the ACTIVE deck.
@ djdirtyharrie
If you need to know what deck Automix will load on you will need to use a skin that displays the MASTERDECK. As far as i can tell the 4 deck skin doesn't do this. It is however available on the six-deck skin - its the "M" in the minidecks.
@ djdirtyharrie
geposted Thu 14 Oct 10 @ 8:28 am
Is there a keyboard shortcut i can create or something I can modify in the skin to give me a button to select which deck is the master deck? I have limited skin making abilities, but i think i could get my way through it. having the master deck tied to the active deck would be a nice thing to have.
geposted Thu 14 Oct 10 @ 9:04 am
djtouchdan wrote :
@ dj-in-norway
@ djdirtyharrie
@ djdirtyharrie
I also noticed this. Was about to post about it. Glad it has been brought up already.
geposted Thu 14 Oct 10 @ 9:34 am
Likewise spotted this while playing earlier. Hey-ho, a minor niggle, there's always something after a major release that causes a X.01 version to get released within a couple of weeks!
geposted Thu 14 Oct 10 @ 9:44 am
just click master on the deck you want ....
i just tried it and it worked i mixed from 1 to 2 , then clicked master on 2 then clicked auto and it started auto
on the 2 deck .....
4 decks 1280 x 768
to change it to 4 , i clicked master on 4 then click auto on and off , reassigns it to 4 apparently, and then it auto
mixed next track to 4
on the 2 deck .....
4 decks 1280 x 768
geposted Thu 14 Oct 10 @ 11:20 am
