Not a biggy, but I have found that whenever I go into the advanced setting on the sound setup to enable the 4 outputs on the soundcard VDJ will often crash with the error message 'Virtual DJ 7 has closed unexpectedly, Windows is searching for a solution' (or words to that effect). This will normally happen when you have made the changes and click 'ok'
I am using a Gigaport HD with the ASIO drivers, managed to get the 4 outputs set so wont be needing to go back into that menu but took me a few attempts before I could do it without it crashing...
geposted Thu 14 Oct 10 @ 2:24 am
i having the same problem i could run 3 decks but not 4 decks. is there any possible fixes?
geposted Fri 27 Dec 13 @ 9:01 pm
