Hello,
I operate a nightclub where several DJs use VDJ. Some of them are ready to try DJing using the Hercules RMX controller, others may not be. If I get the Hercules RMX, can we switch back and forth so that one night we use VDJ with the controller, and then the next with just the mouse/keyboard as if the RMX were not hooked up? In other words, can we just change Configuration settings back and forth whenever we want without having to do any major physical reconfiguring each time?
Thanks,
Steven
Thanks,
Steven
geposted Thu 14 Oct 10 @ 9:37 am
The Keyboard is enabled by default at the same time as any controller connected to the computer,so you can use either or both together at anytime without having to change anything.
geposted Thu 14 Oct 10 @ 10:03 am
Hey Phatso, thanks for the quick reply!
Steven
Steven
geposted Thu 14 Oct 10 @ 10:21 am
