Is there a bug in version 7 when using only one timecode? I can only control the left song,
changing the cue makes no difference.
geposted Thu 14 Oct 10 @ 9:50 am
I came over here and you asked the same question I was about to. I have the same problem because tab doesn't change the deck active control. I can as you rightly said only control the left deck in single timecodes. I'm using a m-audio conectiv. Please help someone?
geposted Thu 14 Oct 10 @ 11:14 am
The auto-switch with "TAB" was removed.
You now have to use the function "timecode_active"
geposted Thu 14 Oct 10 @ 3:45 pm
Thanks DJCel, that solved my problem!
Tab = "deck active select & timecode_active"
geposted Thu 14 Oct 10 @ 8:38 pm
