Hi all,
I'm using a Hercules DJ Console RMX with standard pc Logitech Z323 speakers.
When I connect the green 3,55mm to my computer and attach the Hercules DJ Console RMX I hear a high beep coming from the speakers.
I tried several things like putting a switchbox in between, disconnecting the 3,55mm jack in my computer when using the Hercules DJ Console RMX seems to solve it.
Anyone has any idea to solve it permanently without disconnecting the 3,55mm jack.
Thanks in advance.
Thanks in advance.
geposted Thu 14 Oct 10 @ 12:13 pm
So you are connecting the Rmx to the Line In on the side of the speakers while the main input cable is connected to your computer's soundcard, correct ?
Are the computer and speakers are connected to the same electrical outlet and circuit?
Also, are you using the RCA output of the Rmx? This would be preferable to using the 6.25 mm jack, which have a higher output level, which could induce some noise.
geposted Thu 14 Oct 10 @ 2:43 pm
