Ok sorting out another users problem with 2 CDJ400's I thought I would post here how to 2 CDJs with a 4 deck skin.
First make sure you have the ASIO drivers install for the CDJ400's. Found Here:
http://www.prodjnet.com/support/download/CDJ-2000/Pioneer_CDJ_Driver_1.102.exe
Next make sure windows is not using the soundcard as the default output.
Now open VirtualDJ and go to config>>sound setup. Click on Advanced Config.
Add Deck 1 then choose CDJ400 ASIO and channels 1 & 2
Add Deck 2 then choose CDJ400 ASIO and channels 3 & 4
Add Deck 3 then choose CDJ400 ASIO and channels 1 & 2
Add Deck 4 then choose CDJ400 ASIO and channels 3 & 4
BTW make sure to remove asio4all if you have it on your system.
geposted Thu 14 Oct 10 @ 1:34 pm
