Hi and thanks for this new version !
But I wont be able to play with this version, because I have some bad (digital cracking) sound on the playing song when I load another song from Netsearch into the next channel / player.
Just using 2 channels / players and tried to make it work with more latency (23ms, normaly use 5ms) and safemode ?
I use Windows 7 (32), on a Dell Latitude 630, 4Gb ram.
I do very much mobile gigs and have used Netsearch with no problem with Version 6..
Would like to se some fix for this in next update ;-)
Thanks in advance,
Fredrik
Thanks in advance,
Fredrik
geposted Thu 14 Oct 10 @ 1:35 pm
Problem Solved, Thanks !!
geposted Thu 21 Oct 10 @ 7:31 am
