Hey guys,
Picked up the VMS4 about 2 weeks ago and I'm finally gettin the hang of it with Virtual DJ (still working on Traktor mapping tho, I'm weird i like using both). Anyways one of the things I still can't figure out is how to set more than 4 on-the-fly cue points for any one track. I've got the use of 1-4 down and then when I use SHIFT to try to set 5-8 I realize that that's set to delete 1-4. Is it maybe that 5-8 are solely for the 3&4th decks? Someone's gotta know the answer, help me preez.
geposted Thu 14 Oct 10 @ 4:00 pm
No, in the default mapping we use the Shift+ action for deleting the 1 - 4 Cue points.
This can easily be changed in the Mapper selection if you would like it to set and use CUE points 5 - 8.
Just replace the Delete action with the same action as for 1 - 4 but use number 5 - 8
geposted Thu 14 Oct 10 @ 4:41 pm
could you suggest a good replacement map for the Delete Cue function?
geposted Sun 17 Oct 10 @ 5:18 pm
