Queston - How many queue points can you define per each song? Is it just the 3 for the Hot Cue buttons?
I would love to be able to set more but I cant figure out how. In the mappings it looks like you can set many and I can see that you can rename them too.
Is it just a matter of renaming a cue point away from the default 1,2 or 3 so it doesn't conflict with a queue point?
any help appreciated
geposted Fri 15 Oct 10 @ 8:07 am
Key Learn (press the button you want to use)
Action : hot_cue 4
Action : hot_cue 5
I don't any limit, but I reached 12 hot cue without any problem.
Simple as this.
Have a good day
Action : hot_cue 4
Action : hot_cue 5
Simple as this.
Have a good day
geposted Fri 15 Oct 10 @ 8:21 am
There are more cue points than should ever need :)
geposted Fri 15 Oct 10 @ 11:12 am
