im running with a total control and one dascratch,is there a way to lock the total control so it always controls deck 1 and 2 and doesnt switch to 3 or 4 or switch deck 2 to the deck 1 one side of the total control?,
basically i want the total control to stay locked on deck 1 and 2 but i want to be able to use the dascratch on any channel by changing the deck on dascratch
if this is possible its much apreciated
geposted Sun 17 Oct 10 @ 10:09 am
yap, and easy ;)
In mapper tab, with the Total control connected, click the button next to the controller drop down list, and choose "deck asignment" -> deck 1 and deck 2
geposted Sun 17 Oct 10 @ 5:18 pm
yes i try that but when i switch the deck on dascratch it automatically changes deck 1 on the total control to whatever deck i have dascratch set to
geposted Sun 17 Oct 10 @ 7:14 pm
what button on DaScratch you push?
the "DECK button" ?
geposted Sun 17 Oct 10 @ 8:41 pm
yes deck button
geposted Mon 18 Oct 10 @ 11:57 am
hi i am running virtual dj 7.0 with the xponent connected
i am just wondering is there any way of connecting more than one controller, seeing as there is now more than one deck?
or is there a quick way to change which deck is being controlled, without going through the settings?
thanks,
:D
thanks,
:D
geposted Sun 28 Nov 10 @ 5:48 pm
Yes, you can map controls to switch which deck is being controlled.
You have always been able to connect as many controllers as you physically can.
geposted Sun 28 Nov 10 @ 8:14 pm
craig, there is a quick way
its called buying the software.
geposted Mon 29 Nov 10 @ 4:26 pm
