Hi am having a problem with my denon and virtual dj. I am trying to use my denon with virtual dj but the problem is that the denon connects to virtual dj but doesnt play or move on the screen and freezes. it loads the song but doesnt move. also i get an error with the denon asio when starting up virtual dj. any help will be appreciated. thanks
geposted Sun 17 Oct 10 @ 4:05 pm
Hi there
This sounds more of just an ASIO driver issue than anything else. Could you provide a little more info on how you have this setup? the Denon ASIO driver version? PC? Windows vista or 7?
Let me know and i'll try to help out
Cheers
djwishbone
Cheers
djwishbone
geposted Mon 18 Oct 10 @ 2:14 pm
Hey there i have this set up on Windows Vista and using VDJ 6.1 ; i dont know why im experiencing this problem any help would gladly be appreciated...
geposted Thu 21 Oct 10 @ 8:03 pm
Hi gtsweetbai4u
Are you using Denon controllers? On a PC or Mac and is it a laptop or desktop type PC?
My main problem with having 3 controllers on the same machine was a hard one to find. My computer was slightly overclocked and by doing that really messed up the USB ports. Once I set the clocks back to normal, everything work!
Let me know what you are using and I'll try and help best I can.
djwishbone
djwishbone
geposted Thu 21 Oct 10 @ 9:50 pm
hey im using the denon 5500's with a laptop on windows vista....
geposted Wed 24 Nov 10 @ 5:50 pm
Win Vista is a terrible OS for MIDI controllers.
I’d suggest updating to Win7 when possible.
In the HS5500, you do need to change the “Jog Trans” setting found in the preset mode to 10ms or higher (up to 20ms) for best performance when using Vista.
If you had Win7, this same setting would go down to 3ms.
geposted Wed 24 Nov 10 @ 6:10 pm
