Is it possible to change the way the virtual folders and favourites appear in the section on the left hand side of the browser section. I would prefer them to appear in alphabetical order asi its much easier to find the folder you are looking for
geposted Sun 17 Oct 10 @ 5:36 pm
I dont think it will do it automaticly but since you can easily move folders now it shouldnt be to hard.
Huey
Huey
geposted Sun 17 Oct 10 @ 5:39 pm
Huey
Huey
Its a shame because seems to put the newest at the top, which is ok for current stuff but is makes a mess of older folders, guess i need to do a lot of re-organising
geposted Sun 17 Oct 10 @ 5:46 pm
i found by right clicking in the space in the virtual folders area and choosing 'add virtual folder' it adds the new one to the bottom of the list.
Hope that helps.
Hope that helps.
geposted Sun 17 Oct 10 @ 6:08 pm
Hope that helps.
Hope that helps.
It seems to move it to the top on mine
geposted Sun 17 Oct 10 @ 6:09 pm
