Had a couple of unexplained crashes in VDJ 7.0. Can confirm this is caused by kyokon.svp in the Sonique video effect. If you crash when using sonique (possibly while running firetext), try deleting kyokon.svp from the folder where you have your sonique animations.
geposted Mon 18 Oct 10 @ 2:40 am
Just tried, and found that Kyokon.svp, was not in my Sonique plug in. When did you get this group of visuals?
geposted Mon 18 Oct 10 @ 3:17 am
Could have been from a while back but I have only ever downloaded sonique plugin packs from the vdj site. Maybe someone found it a problem in the past and removed it from the pack. All good - just thought it might help someone else having issues.
geposted Mon 18 Oct 10 @ 8:16 pm
so bar shut down for two weeks for renovations and i decided to wipe my harddrive and reinstall everything. play with it for a week and no problems. get to the bar last night and shuts off on me 5 times. so unplug tv and mixer only ext hardrive and headphones no problems. today i play with it no problems and then starts happening again. found this tip tried it sho nuff fixed it. thanks man
geposted Sat 15 Jan 11 @ 6:08 pm
Also confirm that this plugin is not found in the certified plugins provided by Cel.
geposted Sat 15 Jan 11 @ 10:29 pm
