Hi,
I wonder if anyone can help?
Once you have created a skin and you have your bitmap image file and xlm file, how do you make it into a extractable file so you can just double click on it and it will load into the Skins file like it does when you downlaod an original skin?
Cheers
billy24
Cheers
billy24
geposted Mon 18 Oct 10 @ 6:30 am
It's automatically created for you when uploaded to this website.
geposted Mon 18 Oct 10 @ 6:43 am
Is that the only way it can be created?
because I have made a modification to one for my own use which may not be useful to other people just myself.
so I wanted to make it extractable?
Thanks
billy24
Thanks
billy24
geposted Mon 18 Oct 10 @ 6:48 am
If you're not going to submit it here then all you need is to just zip the two files into a file and place it on your Virtualdj\skins directory.
geposted Mon 18 Oct 10 @ 7:42 am
You don't even need to zip them if you don't want to.
geposted Mon 18 Oct 10 @ 7:52 am
Thanks very much mate
geposted Mon 18 Oct 10 @ 8:01 am
