I'm having issues with my Dennon DN X 1600. I can get the mixer to play audio from VDJ on all 4 channels, but when I try to use 2 timecode vinyls it all goes haywire. I can get it to work for about 20 seconds, then the sound quality quickly distorts and is resulting in crash and or BSOD. I'm running win7 64bit, 4gig ram, dualcore. It works fine with one timecode but for some reason it just doesn't like when I setup 2 in the advanced menu. Another thing I noticed is sometimes the Asio driver will vanish from the advanced setup drop down selection, and the input and output channels keep randomly getting changed as well. It also isn't showing up in VDJ under mappers, only as simple midi wrapper. I would appreciate any help as I only have about 4-5 days to return this mixer if need be. Its a great mixer but I'm thinking if I cant use TC with it there are better options. Thanks guys as always I appreciate it. ( oh and i do have the latest drivers and firmware for the mixer)
-L
-L
geposted Tue 19 Oct 10 @ 1:22 am
