Is there a way to add shortcut keys to the below, because I couldn't figure it out...Thanks in advance:
Under BPM, Edit Grid:
-Set Anchor to First Beat
-Set Anchor to Second Beat
Also, to set shortcut key to Rate songs 1-5.
FLeX, KIR
FLeX, KIR
geposted Tue 19 Oct 10 @ 9:27 am
No automatic way, they assume that when the song is scanned, that is the automatic way.
If it figures it out wrong, make a button with the command "beat_tap". Center the beat you want on the play line in the top waveform. Then press your beat tap button and they will be aligned.
geposted Tue 19 Oct 10 @ 11:16 am
Thanks DHoude,
I program it on my MKII & it was quick to use.
GTG.
FLeX, KIR
GTG.
FLeX, KIR
geposted Thu 21 Oct 10 @ 9:29 am
