I have used djextractor for my promo only and screenplay ...well now I scored about 100 discs that are not supported by djextractor
So now I am looking for help on ripping by chapters but if there is a video that uses 2 chapters it is ripping them speperately I would like it ot be one chapter
I have tried using dvddyvryter and smartripper and I come up with the same results can this be done or am I missing something
Thansk
DJ ED E
Thansk
DJ ED E
geposted Wed 20 Oct 10 @ 11:55 am
I have had luck with dvddecrypter not sure if that is the correct spelling but do a forum search and you will find it. I would post a link but I'm on my phone
geposted Wed 20 Oct 10 @ 1:12 pm
I tried a forum search to no avail ..
geposted Wed 20 Oct 10 @ 2:43 pm
search for "another dvd ripping question"
geposted Wed 20 Oct 10 @ 4:09 pm
I use smartripper, there are options to select chapters and have them rip as separate files or you can choose 1 file. Tick the 2 chapters you want to join and select as one file that way it will join them together.
geposted Wed 20 Oct 10 @ 4:25 pm
+1 for smartripper
geposted Wed 20 Oct 10 @ 4:28 pm
I know you can do this ...basically what I have done is rip all of the files that only have one chapter then I go back and do what you ment
ioned
I am sorry I wasn't clear in my original post...what I want to be able to put a disc in and walk away from my computer come back and have it done just like djextractor does
Anyone have advice ??
Thanks
Ed
geposted Thu 21 Oct 10 @ 2:33 pm
Jam Master Rob wrote :
\\search for "another dvd ripping question"
Thanks that is the setting that I used when I started ripping ..when djextractor was still having all of the bugs in the early versions. I will go back and make sure I have all those setting correct and try it in a few minutes
Thanks
Ed
geposted Thu 21 Oct 10 @ 2:39 pm
Well I jist checked and those are the setting and it still doesn't work
geposted Thu 21 Oct 10 @ 4:12 pm
